Highbeam
Super Member
I just mowed my property line roads over the weekend. The longest is 1200' straight and this is the first time I've needed to mow it. I just run the tractor as close as I can to the fenceposts and it leaves a sharp looking trail. If you can find the corners and see one from the other then you are in great shape to just use a rifle scope setting on one corner looking at the other. Points on line are easy. If you have a single hump between corners from which you can see both corners then you willneed a simple and cheap transit that you can use to loacate your instrument on line and then glass each corner to set points on line.
I have found it very useful to then string the line with mason string so that I can set fence posts. Remember that once you fence the line that you can't get to the other side to remove brush and junk that is setting really close to the fence. So it is pretty important to actually clear a little bit on each side of the fence.
In your line of work, motion activated game cameras have gotten to the point of taking very good and clear color photos that are more than adequate to identify the trespassers. The cameras can be located and operated as not to alert the trespassers to their presence. Your credibility as a deputy goes a long ways towards getting some enforcement done where folks like me are given a lower priority so I think you will find success.
