Clearing Brush, Best Time to do it?
   / Clearing Brush, Best Time to do it? #11
I can't advise you regarding when to do it by the almanac, but I prefer doing this type of work in winter. The leaves are off and you can see what's hidden in the brush easier. It's also more pleasant than in the heat of summer. There's no telling what kind of scrapiron you might find around here on an old farm place.
   / Clearing Brush, Best Time to do it? #12
</font><font color="blue" class="small">( I plan on doing this now and once about May or June then again late next fall. After that I plan on doing it twice the following year then once a year after that hopefully )</font>
You'd better plan on mowing more than that if you are getting rid of blackberies. I can almost mow once a month during growing season if there is rain...
Soundguy
   / Clearing Brush, Best Time to do it? #13
Cut them in spring and hit with roundup when the reshoot. Regular cutting will eliminate them also. There are selective herbicides that work also if you have grass established.
"May take more than one applicatio"
   / Clearing Brush, Best Time to do it? #14
Those berry bushes are like barbed wire for mother nature, They seem to stay around until the canopy blocks the sun. I have a lot that was logged about 2 years ago I now brush hog rows, Make it nice to pick them berries, Might as well eat them because ya cant get rid of them
Sam
   / Clearing Brush, Best Time to do it? #15
If you can spray, you can kill those blackberry bushes with Roundup WeatherMAX. Mix 1 quart to 15 gal. of water. Cover all the foliage and they'll die. I also use the same on cedar, sweetgum and most any other type of tree. I've used WeatherMAX for 3 years now and haven't seen any regrowth.
WeatherMAX is water proof once it's on the plant so you don't have to worry about it being washed off from a rain shower.
   / Clearing Brush, Best Time to do it? #16
Like Glenn9643 I also time my clearing jobs for early spring when all the leaves are off. Not only does this make it easier to see through the brush, there are NO BUGS. A big plus in my book. As for them coming back, one ounce of brush killer or Crossbow per one gallon of water will cure that.
   / Clearing Brush, Best Time to do it? #17
</font><font color="blue" class="small">( so you don't have to worry about it being washed off from a rain shower )</font>
Rain? what's that.. I think I've heard that word before. Isn't that the stuff that happens during hurricanes?
All joking aside... her ein florida.. many of us havn't seen any rain since the hurricanes... which is pretty rough on our pastures.
Soundguy
   / Clearing Brush, Best Time to do it? #18
Yes, that's just old wive's tales.
Best time is when the ground is firm. Otherwise you make a hella' lotta' ruts. Pile the brush up tightly, let dry for 2 weeks, and burn. Make sure the wind is right and the ground is not dangerously dry.
There lots of good information here thanks for all
of the replys. Liberty
   / Clearing Brush, Best Time to do it? #20
I would look at spraying with a roundup & arsenal mix or if you dont have any trees nearby worth saving I would hit it with Spike 20P. Beware of spike it stays in the ground for up to 3 years and continues to work like a champ.
http://www.cdms.net/ldat/ld0B7005.pdf
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
Pickup Truck (A59230)
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2018 FREIGHTLINER M2 SINGLE AXLE DUMP TRUCK (A59575)
2018 FREIGHTLINER...
