fence clearing
/ fence clearing #21
You could use a garbage can to contain the pieces.
I wear a helmet with a mesh face shield when clearing brush. I wouldnt want to get a piece of wire in my eye.
Good decision! My dad was blinded in one eye when a small thorn tree branch flipped and punctured his eyeball. By the time he got to a Dr. the fluid drained out of his eye.
I have a old motorcycle helmet with full-face shield. I even wear it when brushhogging small trees and head-high brush.
/ fence clearing
It's mostly done. It was able to put it in two piles, which is all my mini could push. The third pile has no wire in it. I cut the wire every place I could easily get to it. All those damn vines were harder to deal with than the wire. Now, I will wait for the state to lift the burn ban and pour the diesel to it.
/ fence clearing #23
Bulldozers are not the unbreakable beasts alot of people think they are. Wire on the ground will find a way to tangle in the tracks which almost takes a torch to remove. Then it will make its' way to the hubs and there goes the seals. Remove all the wire you can by hand, then use your machine. A flat tire on a tractor is easier fixed than a flat on a dozer. Ask me how I know that.
/ fence clearing #24
How do you guys roll up or otherwise bundle the lengths of barb wire? I have a lot of it to deal with too and it doesn't come out in very long lengths
I use thick leather gauntlet welding gloves for handling the wire. Wear old work clothes. A leather welding apron and or spats helps if you have them. Old rotten barb wire breaks flat when bent, newer stuff I loop into small bundles for the scrap metal bin.
/ fence clearing #25
Been there, done that, a couple of miles of barbed wire fencing once the livestock was gone. Whack to the fence (power saw and handlebar weed-whacker), pull the staples and clips, roll the wire, pull the metal posts if any, salvage what's good (store, give away, sell), take the rest to a recycler - may get fifty bucks or so.
/ fence clearing
The first two piles of wire and fence post I dug out today after buring. I restacked the burn pile and will get the rest out later this week.
The grass is knee deep so while fire sitting I bush hogged and found more a few post with the mower. View attachment 3259191
/ fence clearing #27
Been doing some of that too. Recent fence is woven wire and barbed wire 80+ years old.
I first clear as much from the fence as possible. Recently been using a new tool, Precision Manufacturing Miniclip that certainly been impressive. Then cut the bigger trees and vines in a section of fence cut free. Pull the posts. With long bottom grapple roll and push up the section, 50-75’. Carry to gulley. Never underestimate the value of a good gulley.
Tree debris go to several piles or gulley. No longer burn. The gulley routinely digests approximately 100tons per year. Valuable farm asset. Has ate a truck, lot of old fences, several buildings, stumps, demolition debris and countless trees for over 50 years. Discharges black top soil quarter mile downhill into a meadow. The piles rot in a several years but not as fast.
EZ loader trailer (A56857)
EZ loader trailer...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
