Clear lighting panels
/ Clear lighting panels #1
USAFpj
SC
1957 841 Powermaster
Did anyone install clear poly-carbonate lighting panels that go under the eaves in your pole barn?
I'll have full lighting throughout, and wonder if these should be discarded as an option. Currently, I'm looking at having (3) 2x10 panels placed on the length sidewall ($500). This barn will be insulated, with (2) 10x10 doors on a 14ft height. I'm thinking it would be better served to remove those panels, and put the money towards keeping (1) 10x10 door, but installing a 12x12 door as well.
Didn't have this many decisions to make when building our home:rolleyes:
/ Clear lighting panels #2
Kinda depends on your use of the building IMO.
Clear Panels (unless you get good ones) provide no insulation. in SC maybe not an issue? They do provide light, I think they have a shorter life span than regular siding but I am not sure how much that really matters.
My neighbor builds these for a living (larger, warehouse size). He is all for insulating and not much for clear panels (we get 10 days a year below 32 as an average). I question him a lot on this because his shop doors are always open (he personally has an 80x60) and the doors themselves seem to have little R Value.
Like I said, I think if I lived in Montana, I would not have clear panels if I was using insulation. Warmer climates, even with insulations, might not be a bad thing as they do provide some solid working light.
/ Clear lighting panels #3
I used double wall polycarbonate greenhouse panels, and the ambient light in the day is sufficient to light the barn. Its an unheated space, but I think the air space does allow for some heat retention. The triple wall products are used in cold climate greenhouses and have some insulation value.
/ Clear lighting panels #4
They don't recommend clear panels if the building is insulated. I put them on my uninsulated pole shed but I don't have power on the property. Apparently they have a 15 year UV warranty.
/ Clear lighting panels #5
They don't last 15 years down here. You'd be lucky to get five years. They cloud up and turn brown in this South Texas sun. I've replaced mine three times already in the last 10 years. When I re-do the barn roof line and extend it out, I'm dumping those light panels.
/ Clear lighting panels #6
One thing to look at is Costco's.... They are designed to be incredibly energy efficient for the size. The two I use have skylights that must have some sort of insulative property. They do a bunch of other tricks as well (fans in front, use heat off the refrigeration systems).
/ Clear lighting panels #7
The builder put them on the side walls, not the roof, 4 years ago, still look like new.
Xfax- do you have power to your barn? I just don't know if I 'need' them if I have a lot of adequate electrical lighting:confused3:
/ Clear lighting panels #9
I have the originals still on my barn. 26 yrs old. The barn has power, but no insulation. They are dirty for sure, but still let good light in during daylight. I can't even guess how many times I have left the lights on at the end of the day, hate having to go back outside in the dark and rain to turn them off.
/ Clear lighting panels #10
Yes, but don't have to turn on the LED lights during daylight. :thumbsup:
Man, that's nice! Thanks for adding to my dilemma on what to go with:confused2:
/ Clear lighting panels #12
Have a friend that put in some thermopane windows at the top of the wall.
They let in more light than the panels.
/ Clear lighting panels #13
I put the clear panels on the sides of my barn. While I don't have the big doors on yet, I can tell I will not need lights during the day.
I do not plan to insulate or heat. As you can see it's just like being outside with all the light that comes in.
Waiting for doors but everything else is done.
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
2005 Chevrolet 2500HD (A66408)
2005 Chevrolet...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
12 in. WRXLS Excavator Bucket Attachment (A64194)
12 in. WRXLS...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
