Cleaning Up Substantial Yard Debris
   / Cleaning Up Substantial Yard Debris #21
would you consider buying run flat tires and a grapple for your existing tractor? sell when finished.
also around here if they have 80 acres like you they would dig a big hole and fill with all your "junk" somewhere way out of the way. Cover and keep excess fill for other projects. (burn down in winter also common before covering. Don't know though if legal in your area or if any of your "valuables" could be toxic.
long run probably cost very little or nothing in the long run versus time and money to haul off site..
I have a root rake grapple like this one a nd would be well suited to "rake" a field of junk and dump in big holes.
junk yards and metal recycling depots often use run flat tires like these.
Compact Tractor Loader Dual Lid Wicked Root Grapple
MICHELIN X TWEEL TURF Airless Radial Tire | John Deere US
   / Cleaning Up Substantial Yard Debris #22
Big roll off dumpsters and lots of hand work
Plaster - I forgot about this tool. I used this just this last week to burn the underbrush along the fence line along one of the public roads making up our farm boundary. It did not burn the brush. Once burned, I could see the bottles, shoes, etc. that had been thrown there over the years. I think the brush might have burned if I held the flame to it long enough. I also think if you used a weed trimmer (remove the string and put on the circular saw), if you cut the brush just above the debris, and let it lay for 6 months, it then would burn handily. As it was, the branches were too far away from each other to get a good burn going. I used about a gallon of propane an hour, working the way I described. The mfg. says with my unit (a six footer), to get a 100 lb. propane tank. I used 40 lbs, and it will work fine for my purposes which are primarily maintenance of the fence, not cleaning up the fence line.
Those are VERY cool but I think my wife would lose it if I started trying to blowtorch the garbage.
Everybody recommends the dig and bury method. Considering it's old agricultural land and a multigenerational family property, that and I'm a bit crunch, I'd rather just pick it all up. Small stuff can be raked into the top soil season after season but that'd be the extent of it. Those run flats are real cool though. How well do they perform?
   / Cleaning Up Substantial Yard Debris #24
I understand about the wife. I waited until she went shopping, tested the "burn" in an area where it couldn't spread to the nearby woods, and "went for it". I also burned 2 days after a snow, so the ground was still wet - the snow had melted, but the ground was wet.
And I'm with you about not wanting to bury the debris. I don't know what a "crunch" is, but I didn't want to defile the earth. This also is a multi-generational farm. The former occupants may have been too infirm to deal with their debris, but I'm able. There is an end to it. I don't pick and haul every day, but I'll be finished by the end of our 2nd year here.
Where are you in New England ?
Sorry, I meant crunchy, as in a crunchy granola type. I'm in Southern Vermont in a pretty desirable area but the property fell into disuse and was then absentee landlords to a series of scumbag over thirty years who just trashed it. The house is being renovated in stages but it's really rough. I wish I could say it has good bones but it's seen so much neglect.
It's good to talk to somebody in the same situation. Where are you located? Any special precautions you take for punctures? I've got R1s so I can nervous about everything.
   / Cleaning Up Substantial Yard Debris #26
Some landowners live remotely, and are not always present for many years to protect access, so people will dump. The best time to attack the hidden junk on land problem, is wait until fall to early winter, when the trees and brush do not hide as much of the debris.
Rent a dumpster, and then use a tractor with a grapple or bucket, to pickup and move debris to the dumpster. When its full just call for pickup. Most landfills will not allow rubber tires and refrigerators, so these cannot be put in the dumpster. You may have to recycle the tires, and pay extra fee for landfills to take old refrigerators. This may take a few years , but be persistent and the junk will all be gone. I had this problem, and after 18 dumpsters, about 95% of the junk is now gone.
Yeah, I definitely see this as a long-term issue. It's a disappointment because I'd played around with the idea of starting a campground but it's frankly a little embarrassing when people pull around back. So I'm just going to chip away.
The remote junk in the middle of the woods is what bugs me the most. The property is big enough that I have a tough time knowing what's going on in it. When I find active deer stands I just put a No Trespassing sign on them. I really resent having to wear orange on my own property during hunting season when we're posted.
   / Cleaning Up Substantial Yard Debris #28
Plasterprospector: As the landowner, you have changed the rules for your land, and it won't take long for everyone to realize that. Most of the junk on my property dated back to 1940 to 1970 when centralized landfills managed by the county were simply not present. I suspect that's probably the typical case for most junk on property today.
During the early part of the pandemic, dumpster costs dropped to $350 for a 14-Cubic yard dumpster, good for one week rental. For me, requiring 18 dumpsters, I spent total $6300 to haul 95% of the junk away. Loading takes about 3 to 4 days per dumpster.
   / Cleaning Up Substantial Yard Debris #29
rademamj1 - I tip my hat to you. 18 dumpsters would have been an overwhelming amount for me. Our land fill takes tires, but $2 for passenger tires, up to $35 for tractor tire on rim. Metal I took to the recycle place and sold. I went there so much, they started to unload my truck for me.
   / Cleaning Up Substantial Yard Debris #30
Hey folks, I moved onto about 80 acres and the first five of it have been used as a junkyard for all kinds of miscellaneous debris and junk. I've got tires, washing machines, broken bottles, rotted mattresses, three sets of crutches (?), rotted old furniture with nails sticking out and so much more. It's been accumulated by poor stewards over the last thirty years and most of it is so small I've only been able to use my tractor as a glorified wheelbarrow while I hand load the FEL. I've already done two 30yd dumpsters for just the easy stuff. Now that the leaves are off the trees I can see that it's so much worse than I imagined. It's a million tiny pieces of junk seemingly everywhere in the brush. I've already had two punctures in the last few months.
Anyone have any experience cleaning up this sort of thing before? I bought a metal detector and a magnetic sweep but it feels like I'm picking needles off a pine tree. Would a skeleton bucket be useful or maybe some other attachment? I looked into hanging magnets and magnetizing my bucket but my terrain is so uneven.
Yes. Bulldozer or large excavator with steel tracks. Load it all out then bring in fill and regrade it with said bulldozer.
(APPROX 18) 2" X 6" X 68" TUBING (A54756)
(APPROX 18) 2" X...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
ASCO Transfer Switch (A52377)
ASCO Transfer...
Wolverine Hydraulic Slope Mower Skid Steer Attachment (A55787)
Wolverine...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
1996 Elgin Pelican Series S Street Sweeper (A55787)
1996 Elgin Pelican...
