Oil & Fuel Cleaning sediment from kerosene cans
   / Cleaning sediment from kerosene cans #1
mccash40
Adirondacks, NY
kubotabx2360
I was wondering if anyone had some hints on what I could use to clean out some used 5 gal plastic kerosene cans? There appears to be some sediment in the bottoms and I want to refill them with diesel for my tractor. Thanks in advance.
   / Cleaning sediment from kerosene cans #2
If the sediment is dried kerosene then add some more kerosene and let it soak. Then rinse it out. Maybe try a pressure washer to knock it loose. WD40 will help break it up.
   / Cleaning sediment from kerosene cans #3
I'd use a little gasoline. Dump some in, close the can, shake it and let it sit for a while. Dump, repeat if necessary.
   / Cleaning sediment from kerosene cans #4
The final rinse should be using the product you intend to store in the cans
   / Cleaning sediment from kerosene cans #5
Castrol Super Clean and hot water then rinse with alcohol, a small amount of dry gas will absorb the water.
Amazon.com: castrol super clean
Those cans will be spotless, Fred
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2020 DRAGON ESP...
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
2006 iDrive...
