Oil & Fuel Cleaning sediment from kerosene cans
/ Cleaning sediment from kerosene cans #1
mccash40
Adirondacks, NY
kubotabx2360
I was wondering if anyone had some hints on what I could use to clean out some used 5 gal plastic kerosene cans? There appears to be some sediment in the bottoms and I want to refill them with diesel for my tractor. Thanks in advance.
/ Cleaning sediment from kerosene cans #2
If the sediment is dried kerosene then add some more kerosene and let it soak. Then rinse it out. Maybe try a pressure washer to knock it loose. WD40 will help break it up.
/ Cleaning sediment from kerosene cans #3
I'd use a little gasoline. Dump some in, close the can, shake it and let it sit for a while. Dump, repeat if necessary.
/ Cleaning sediment from kerosene cans #4
The final rinse should be using the product you intend to store in the cans
/ Cleaning sediment from kerosene cans #5
Castrol Super Clean and hot water then rinse with alcohol, a small amount of dry gas will absorb the water.
Amazon.com: castrol super clean
Those cans will be spotless, Fred
BUYERS PREMIUM & PAYMENT TERMS (A59908)
BUYERS PREMIUM &...
CASE TV380 SKID STEER (A62129)
CASE TV380 SKID...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2015 PETERBILT 579...
