Oil & Fuel Cleaning sediment from kerosene cans
   / Cleaning sediment from kerosene cans #1
mccash40
Adirondacks, NY
kubotabx2360
I was wondering if anyone had some hints on what I could use to clean out some used 5 gal plastic kerosene cans? There appears to be some sediment in the bottoms and I want to refill them with diesel for my tractor. Thanks in advance.
   / Cleaning sediment from kerosene cans #2
If the sediment is dried kerosene then add some more kerosene and let it soak. Then rinse it out. Maybe try a pressure washer to knock it loose. WD40 will help break it up.
   / Cleaning sediment from kerosene cans #3
I'd use a little gasoline. Dump some in, close the can, shake it and let it sit for a while. Dump, repeat if necessary.
   / Cleaning sediment from kerosene cans #4
The final rinse should be using the product you intend to store in the cans
   / Cleaning sediment from kerosene cans #5
Castrol Super Clean and hot water then rinse with alcohol, a small amount of dry gas will absorb the water.
Amazon.com: castrol super clean
Those cans will be spotless, Fred
1986 GMC Top Kick Grain Truck (A50514)
1986 GMC Top Kick...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
