Cleaning Bug goo
/ Cleaning Bug goo #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I know many probably already know this one, but I had never heard it, and was just amazed at how well it worked.
I was washing my truck and could not get the bug goo off the front, tried different bottles of bug and tar remover, following the directions etc, and it was still bug gut covered.
Speaking with my dad last night, he said wet a dryer sheet (like Bounce) mine was the one from Sams Club, anyway, walked out in the rain, and started wiping the front down with that dryer sheet and man it came incredibly clean with no effort.
Just love it when things work, they are cheap, and I already keep them around.
Just thought I would share.
/ Cleaning Bug goo #2
Yeah, but did it get the wrinkles out? :rolleyes:
Seriously though, I'll give it a try. Thanks.
/ Cleaning Bug goo #3
Thanks for the tip
/ Cleaning Bug goo #4
I have hard this but yet to try it. At the airport we use 75% white vinegar, 25% water in a old spay bottle on the airplanes. Spay it on the bugs and let it sit for 15 seconds or longer if need and wipe off with a soft towel. Works great and is dirt cheap.
Chris
/ Cleaning Bug goo #5
I use the dryer sheet trick every time I want to get my truck really clean when I wash it. It works great. I have noticed that when I finish it leaves a slight film on the chrome, but a quick wipe with a microfiber towel and the chrome really shines. There's hardly any rubbing to get bugs off with a dryer sheet.
/ Cleaning Bug goo #6
Interesting concept. I'll have to give that a try. So far that's two ways to use bounce on tractors/cars. 1. keep mice away. 2. clean bug goo . Hmm I see a trend here - bounce takes care of critter issues. I wonder if it wouldd work with deer ? :p
/ Cleaning Bug goo
Dryer sheets keep mice away?
Got to try that one, they are making a very happy (dry) home in the dump truck and the backhoe.
/ Cleaning Bug goo #8
I gotta try this too..
the Finish mower has been sitting in the garage for months and not used.
I was cleaning up yesterday and found that a rat or mouse or something made a big nest under the belt guard...
THANKS!!
J
/ Cleaning Bug goo #9
So is it the stuff on the dryer sheets that helps "cut" the bugs or is it just the sheet itself is a good scrubber? Stated differently, do used sheets (after they have been used in the dryer) or do they need to be new unused sheets?
Recently I was fixing my mom's dryer and noticed a little note in the owners manual regarding those dryer sheets and the drying performance of the dryer. It stated that the dryer sheets will 'clog' the lint trap filter screen on the dryer. (it basically builds up on the screen) It recommended using very HOT water and a nail brush to clean the lint trap and remove the build up of the residue. It didn't look like anything was on it until, I tried it.
/ Cleaning Bug goo #10
I'll have to try that. My truck seems to clean up pretty good from bugs (2007 Dodge) but my wife 300C doesn't. It seems like the softer plastic front ends they put on cars are hard to get the bugs off.
/ Cleaning Bug goo #11
I'm really not sure about using "used" dryer sheets. I've always used new ones, and it usually takes 2 sheets to do the front end of my Titan. I suspect used sheets wouldn't cut it, because about halfway through the front end I begin noticing diminished performance cutting bug goo so I switch to a new sheet to finish up.
I know what you're talking about with the dryer sheet build-up, though I hadn't thought about it building up on the lint filter. After cleaning the bug goo off the bumper and grille, I've noticed that the dryer sheet leaves a slick white film on the front end that needs to be wiped off, either with a microfiber cloth or a quick wipedown with the sponge. It comes right off though, and the dryer sheets still save a lot of elbow grease cleaning off the bug guts.
/ Cleaning Bug goo #12
You are missing half the trick. You are to leave the film ON, and the next time you go to wipe the bugs off they come off twice as easy!!
Jeff
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
