Cleaning around your zerks and grease areas?
   / Cleaning around your zerks and grease areas? #41
I power wash the old grease off and the zerk fitting. Then grease until just a small amount of grease comes out. Usually a little water comes out first. I do not like a lot of grease around the joint because it attracts dirt.
Dan
   / Cleaning around your zerks and grease areas? #42
I use Scotts blue shop towels buy them by the case and I only add grease till I see cleaner grease coming out edges then wipe off old crud, I also wear rubber gloves so hands don't get too greasy. zerks get wiped before and after.
too much grease will hold dirt and cause wear on moving parts
   / Cleaning around your zerks and grease areas? #43
wipe with the thumb, then thumb on the pants...
   / Cleaning around your zerks and grease areas? #45
Is it safe to pressure wash around bushings, etc? Couldn't the pressure force water through the seals and do damage. I have been avoiding using my pressure washer on the advice of my dealer.
   / Cleaning around your zerks and grease areas? #46
I have been meaning to buy one of the Univer-co lock on grease couplers that are made in Canada. They are a bit more expensive than the locknlube ($32) but they are the same size as a regular coupler. I have a couple spots on my backhoe that I can barely get a regular coupler into. I think I could save the price in just grease cost. I see Rural King has them if you guys have one of those nearby.
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
J and L Cargo Express Shadowmaster Enclosed Trailer (A56435)
J and L Cargo...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
