Cleaning around your zerks and grease areas?
   / Cleaning around your zerks and grease areas? #41
I power wash the old grease off and the zerk fitting. Then grease until just a small amount of grease comes out. Usually a little water comes out first. I do not like a lot of grease around the joint because it attracts dirt.
Dan
   / Cleaning around your zerks and grease areas? #42
I use Scotts blue shop towels buy them by the case and I only add grease till I see cleaner grease coming out edges then wipe off old crud, I also wear rubber gloves so hands don't get too greasy. zerks get wiped before and after.
too much grease will hold dirt and cause wear on moving parts
   / Cleaning around your zerks and grease areas? #43
wipe with the thumb, then thumb on the pants...
   / Cleaning around your zerks and grease areas? #45
Is it safe to pressure wash around bushings, etc? Couldn't the pressure force water through the seals and do damage. I have been avoiding using my pressure washer on the advice of my dealer.
   / Cleaning around your zerks and grease areas? #46
I have been meaning to buy one of the Univer-co lock on grease couplers that are made in Canada. They are a bit more expensive than the locknlube ($32) but they are the same size as a regular coupler. I have a couple spots on my backhoe that I can barely get a regular coupler into. I think I could save the price in just grease cost. I see Rural King has them if you guys have one of those nearby.
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2014 FREIGHTLINER...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
John Deere 3025E (A53317)
John Deere 3025E...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
