clean a slab...best way
   / clean a slab...best way #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Anyone ever had to clean years of paint off a concrete slab? If so, how did you do it.I tried a pressure washer 2200psi and it barely phased it.Chemicals would be very messy also.Any thoughts will be much appreciated.
   / clean a slab...best way #2
I'm sure a rental would have a floor sander with a special disc for concrete floors that would take it down in a hurry. I know that if you use a diamond disc it will cut into the concrete so you would have to careful. But a floor sander will work for you.
   / clean a slab...best way #3
These work sweet, makes a huge mess. Seal afterwards.
   / clean a slab...best way #5
Mornin Bones,
When I first saw your thread title I was ready to jump in and suggest muriatic acid, which works quite well for removing all kinds of stuff from the concrete surface. Then I read a bit more to see its a painted floor :( I think the advice on the sander with the proper pads woud work well. Ill bet the ORANGE store would have just what you need in their renatl department.
   / clean a slab...best way #6
pressure washer.... 2200 psi is just getting started.... try a real pressure washer (comercial type) 5000 psi with a 5 deg tip. not only will you take the paint off but the top layer of concreet also. (warning you can very effectivly bore holes in concreet with the 0deg tip... )
1989 22ft T/A Gooseneck Flatbed Equipment Trailer (A52377)
1989 22ft T/A...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A54313)
2015 VOLVO VNL64T...
Year: 2017 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A54814)
Year: 2017 Make...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
