clean a slab...best way
   / clean a slab...best way #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Anyone ever had to clean years of paint off a concrete slab? If so, how did you do it.I tried a pressure washer 2200psi and it barely phased it.Chemicals would be very messy also.Any thoughts will be much appreciated.
   / clean a slab...best way #2
I'm sure a rental would have a floor sander with a special disc for concrete floors that would take it down in a hurry. I know that if you use a diamond disc it will cut into the concrete so you would have to careful. But a floor sander will work for you.
   / clean a slab...best way #3
These work sweet, makes a huge mess. Seal afterwards.
   / clean a slab...best way #5
Mornin Bones,
When I first saw your thread title I was ready to jump in and suggest muriatic acid, which works quite well for removing all kinds of stuff from the concrete surface. Then I read a bit more to see its a painted floor :( I think the advice on the sander with the proper pads woud work well. Ill bet the ORANGE store would have just what you need in their renatl department.
   / clean a slab...best way #6
pressure washer.... 2200 psi is just getting started.... try a real pressure washer (comercial type) 5000 psi with a 5 deg tip. not only will you take the paint off but the top layer of concreet also. (warning you can very effectivly bore holes in concreet with the 0deg tip... )
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
