clean a slab...best way
   / clean a slab...best way #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Anyone ever had to clean years of paint off a concrete slab? If so, how did you do it.I tried a pressure washer 2200psi and it barely phased it.Chemicals would be very messy also.Any thoughts will be much appreciated.
   / clean a slab...best way #2
I'm sure a rental would have a floor sander with a special disc for concrete floors that would take it down in a hurry. I know that if you use a diamond disc it will cut into the concrete so you would have to careful. But a floor sander will work for you.
   / clean a slab...best way #3
These work sweet, makes a huge mess. Seal afterwards.
   / clean a slab...best way #5
Mornin Bones,
When I first saw your thread title I was ready to jump in and suggest muriatic acid, which works quite well for removing all kinds of stuff from the concrete surface. Then I read a bit more to see its a painted floor :( I think the advice on the sander with the proper pads woud work well. Ill bet the ORANGE store would have just what you need in their renatl department.
   / clean a slab...best way #6
pressure washer.... 2200 psi is just getting started.... try a real pressure washer (comercial type) 5000 psi with a 5 deg tip. not only will you take the paint off but the top layer of concreet also. (warning you can very effectivly bore holes in concreet with the 0deg tip... )
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2014 John Deere 244J (A47477)
2014 John Deere...
