clean a slab...best way
   / clean a slab...best way #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Anyone ever had to clean years of paint off a concrete slab? If so, how did you do it.I tried a pressure washer 2200psi and it barely phased it.Chemicals would be very messy also.Any thoughts will be much appreciated.
   / clean a slab...best way #2
I'm sure a rental would have a floor sander with a special disc for concrete floors that would take it down in a hurry. I know that if you use a diamond disc it will cut into the concrete so you would have to careful. But a floor sander will work for you.
   / clean a slab...best way #3
These work sweet, makes a huge mess. Seal afterwards.
   / clean a slab...best way #5
Mornin Bones,
When I first saw your thread title I was ready to jump in and suggest muriatic acid, which works quite well for removing all kinds of stuff from the concrete surface. Then I read a bit more to see its a painted floor :( I think the advice on the sander with the proper pads woud work well. Ill bet the ORANGE store would have just what you need in their renatl department.
   / clean a slab...best way #6
pressure washer.... 2200 psi is just getting started.... try a real pressure washer (comercial type) 5000 psi with a 5 deg tip. not only will you take the paint off but the top layer of concreet also. (warning you can very effectivly bore holes in concreet with the 0deg tip... )
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2019 FREIGHTLINER CASCADIA SLEEPER (A54607)
2019 FREIGHTLINER...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2023 Country Clipper Boulevard 54in Zero Turn Commercial Mower (A52377)
2023 Country...
Croft 5,000lb Vehicle Tow Dolly (A52377)
Croft 5,000lb...
2003 12FT Paris Utility Tilt Trailer (A52377)
2003 12FT Paris...
