class 3 belly guard-done
/ class 3 belly guard-done #1
kcbarnes
michigan
TC40D,woods M2050 ztr
I finally found all the stuff I needed to make a guard for the belly of my TC40D. Not to bad to make at all, I started with a piece of diamond plate 48" by 31" by 1/8" thick and added some 3/8" by 6" and 3/8 ' by 2" cross straps for support and for space to clear some stuff toward the rear. To attach it I used some 3/8" by 2" bent in a 90 to hook over the loader sub frame and 1/2" bolts to clamp it on.
Kevin
Another view
Kevin
/ class 3 belly guard-done #3
Really cool! Nice job! I was changing oil on my TC45D today and looking at the subframe thinking of a skid plate. Yours is an inspiration. Do you have drawings?
JimI
I will try to draw something in my cad program in the next day or so and figure a way to post it
Kevin
Sorry Jim. I drew up a couple of views in turbocad but no way of changing the file format to one that will post.
Kevin
/ class 3 belly guard-done #6
What about printing it, scanning it as a .gif and posting it?
/ class 3 belly guard-done #7
Actually, your pictures are probably the best "pattern" since I would have to make final measurements anyhow. A photo of the attaching hardware by itself might also be helpful. You've actually done the hard work by proving that it can be done. I'll just save your photos until I get a chance to build my own. Thanks /w3tcompact/icons/smile.gif
JimI
Here is a closeup of the clamp setup with a piece of 3/8 by 2 flat stock bent in a "L" and hooking over the sub frame. I have no scanner so I can't print and scan. If you want I can send the drawings in an email to you in a dwg. format.
Kevin
/ class 3 belly guard-done #9
How do you cut 3/8" thick stock, and how do you bend to such a small radius?
/ class 3 belly guard-done #10
yep, like I figured, you improved on what I did --- looks good!
mike
/ class 3 belly guard-done #11
Your picture is perfect. I don't think I need anymore than that. Thanks!
JimI
Mike thank you for the input, it made it an easy job. To cut the steel and bend it I have access to a chop saw and torches.
Kevin
/ class 3 belly guard-done #13
There's the difference - I don't have access to a chop saw or the real difference ... <font color=red>talent</font color=red> /w3tcompact/icons/smile.gif
mike
/ class 3 belly guard-done #14
Kevin
Your skid plate looks great!
Does your TC40 have FWD and supersteer?
On my TC45D with FWD and supersteer there is a shaft that would prevent the skid plate from extending to the front edge of the loader frame. The plate would have to be mounted lower or have a notch cut out for the shaft.
Tim
/ class 3 belly guard-done #15
One way I post things in specialty programs is hit printscreen and then save it or paste it to word or paint as a bit map.then convert to a jpeg...Your plate looks great....looking forward to the drawings.
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif
Lil' Paul
Proud owner of TC21D
Thanks Tim, My tractor is mfwd w/o supersteer. so I wouldn't know what to change for the supersteer clearance.
Kevin
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
Kubota Z232 (A60462)
LOOK! (A63111)
LOOK! (A63111)
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
