Clamshell driveway
/ Clamshell driveway #21
We are trying our best to deal with this! IMG_0498.jpgIMG_0500.jpgIMG_0506.jpg
Tommy White is the guy's name, he's a lifetime local and a good guy. Tell him Randy from Airport road sent you.
It's not uncommon for it to take an extra load to load and a half from the estimate, just depends on the base and how wide you do it.
Louisiana, Alabama, Mississippi, Georgia, Florida, south and North Carolina and some in Virginia, the coastal areas are loaded with old shell roads.
/ Clamshell driveway #26
Artist I am not,I just took some crude measurements and heres a picture of where we are getting driveway. Whats your opinion on how many loads it will take? How thick is it generally laid? Was yours done in one day?
/ Clamshell driveway #29
check this website out, lotview.net allows you to mark out an area to measure area.. or you can do just straight lines,
i use it all the time. here's what i came up with using it with your drawing (best i could mimic)
Mine is around 140' by 16' with 2 turnouts one single and a half wide, one two cars plus wide, mine was $2250. I had a good hard base below mine and that helps. He did all the leveling and prep work and had it all but about half a load done in one day.
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
