CK3510SEHST Competitors
/ CK3510SEHST Competitors #1
cwb440
2007 Kioti ck30hst
I currently own a CK30HST and like it. But thinking about a new 35hp. As long as I'm looking, what John Deere or Kubota models are comparable? The Deere's all seem a little lighter without going up to a 4 series event though they offer similar horsepower and lifting capacity. I do like not needing ballast boxes or wheel weights all the time.
/ CK3510SEHST Competitors #2
Look into the MT2 or the MT3 series from LS. They would outspec the Kub or JD, at a lower price.
Or, just stick with Kioti..... you like the one you have. Get a bigger new Kioti, they are good machines.
/ CK3510SEHST Competitors #4
I currently own a CK30HST.
Kioti CK30 Dimensions​
Dimensions
Wheelbase:66.1 inches
167 cm
Length:122.2 inches
310 cm
Width:54.6 inches
138 cm
Height (ROPS):96.8 inches
245 cm
Gear Weight:3042 lbs
1379 kg
Hydro Weight:3055 lbs
1385 kg
Ground clearance:13.82 inches
35 cm
Front tread:43.5 inches
110 cm
Rear tread:38.2 to 51.3 inches
97 to 130 cm
Tractor capability is more closely correlated to tractor weight than any other single specification.
Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Perhaps you need a rear-engine Skid Steer or rear-engine Compact Track Loader rather than a front-engine tractor.
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
1998 JD #8300 MFWD (A68191)
1998 JD #8300 MFWD...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2017 Ford F-150...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Generator (A64553)
Generator (A64553)
