Ck3510hse backhoe.
/ Ck3510hse backhoe. #1
steviep
Milton NH
2001 JD 4300
I been wondering if there is a list of backhoes that fit my 2018 ck3510se . I have seen a few kioti backhoe forsale on craigslist and it got me thinking
/ Ck3510hse backhoe. #3
With the amount of stress a backhoe puts on a tractor, I wouldn't use anything other than a properly fitted OEM backhoe with subframe. If you happen to find an exact match, go for it.
I found one on capitalist it's a kb2385 off a DK38se.
/ Ck3510hse backhoe. #6
I started with a new ck 20 fitted with a new KB 2465 back hoe. After a few years and 1500 hours on the ck20 I sold it but kept the backhoe that was on the 20 and installed it on the new CK2510 I bought. The 2510 WORKED my retrofitted backhoe anotiher 400 hours or so withougt any problems. between these two tractors that shared this backhoeo I never met a stump I could not pull. I also used it too dig crawl space foundations an water lines plus anything else I askeed of it. These Kioti backhoes have proven them selves so far as I can see. No need for me to say more other then if the backhoe fits......wear it on that Kioti tractor.
rim
/ Ck3510hse backhoe. #7
Funny, we're in the same general area, and I've seen a few KB2385's on CL lately and have the same question about fitment... I have a CK2610.
I have now found a kb2375 locally off a ck30. I wish there interchange list for all models not just new ones.
/ Ck3510hse backhoe. #9
The KB2375 Backhoe is the older "Straight Boom" backhoe that was originally for the CK and LK Series KIOTI Tractors. It would be a reasonable fit, but you would need to purchase the proper Backhoe Subframe for your CK10 Tractor. A subframe from the CK or LK Series would not fit the Transmission of the CK10 Series Tractors. With any KIOTI Backhoe, you will need a CK10 Backhoe Subframe. The recommended Backhoe for the CK10 Tractors is the KB2475L.
Hope this helps.
/ Ck3510hse backhoe. #12
Lots of people spend time and money getting there equipment just so before they even use it, thinking it will be great then the need never arises.
/ Ck3510hse backhoe. #13
He only used it 4 times, but felt the need to convert the controls? Sounds a bit fishy...
Some operators are very used to CAT controls and others for the Deere controls. I had borrowed an excavator that was set to CAT. I had a hard time using it because it wasn't what I was used to. Fighting instinctive/automatic hand movements was hard. Luckily it had a change over valve and I went to Deere. Now it felt normal. All he had to do was change a few hose connections to be able to have instinctive controls.
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2016 FORD TRANSIT CONNECT PASSENGER VAN (A59912)
2016 FORD TRANSIT...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
