Ck3510hse backhoe.
/ Ck3510hse backhoe. #1
steviep
Milton NH
2001 JD 4300
I been wondering if there is a list of backhoes that fit my 2018 ck3510se . I have seen a few kioti backhoe forsale on craigslist and it got me thinking
/ Ck3510hse backhoe. #3
With the amount of stress a backhoe puts on a tractor, I wouldn't use anything other than a properly fitted OEM backhoe with subframe. If you happen to find an exact match, go for it.
I found one on capitalist it's a kb2385 off a DK38se.
/ Ck3510hse backhoe. #6
I started with a new ck 20 fitted with a new KB 2465 back hoe. After a few years and 1500 hours on the ck20 I sold it but kept the backhoe that was on the 20 and installed it on the new CK2510 I bought. The 2510 WORKED my retrofitted backhoe anotiher 400 hours or so withougt any problems. between these two tractors that shared this backhoeo I never met a stump I could not pull. I also used it too dig crawl space foundations an water lines plus anything else I askeed of it. These Kioti backhoes have proven them selves so far as I can see. No need for me to say more other then if the backhoe fits......wear it on that Kioti tractor.
rim
/ Ck3510hse backhoe. #7
Funny, we're in the same general area, and I've seen a few KB2385's on CL lately and have the same question about fitment... I have a CK2610.
I have now found a kb2375 locally off a ck30. I wish there interchange list for all models not just new ones.
/ Ck3510hse backhoe. #9
The KB2375 Backhoe is the older "Straight Boom" backhoe that was originally for the CK and LK Series KIOTI Tractors. It would be a reasonable fit, but you would need to purchase the proper Backhoe Subframe for your CK10 Tractor. A subframe from the CK or LK Series would not fit the Transmission of the CK10 Series Tractors. With any KIOTI Backhoe, you will need a CK10 Backhoe Subframe. The recommended Backhoe for the CK10 Tractors is the KB2475L.
Hope this helps.
/ Ck3510hse backhoe. #12
Lots of people spend time and money getting there equipment just so before they even use it, thinking it will be great then the need never arises.
/ Ck3510hse backhoe. #13
He only used it 4 times, but felt the need to convert the controls? Sounds a bit fishy...
Some operators are very used to CAT controls and others for the Deere controls. I had borrowed an excavator that was set to CAT. I had a hard time using it because it wasn't what I was used to. Fighting instinctive/automatic hand movements was hard. Luckily it had a change over valve and I went to Deere. Now it felt normal. All he had to do was change a few hose connections to be able to have instinctive controls.
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
UNUSED AGT ATK- TC 24 TIRE CHANGER (A64281)
UNUSED AGT ATK- TC...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
