CK3510 Fuel Heater
/ CK3510 Fuel Heater #1
Bigal0043
Plattsburgh NY
Ck3510
I saw the other post about a CK2610 gelling up. Same happened to me today. Its been -10 for the past week straight. I used the additive to prevent gelling. Same thing as the other post, started rough, ran a couple minutes then surging up and down. Then would die.
This happened last year to me as well. Do they make a fuel heater that I can install to never have these issues? If so, anyone have the part number and how to install it?
Alex
/ CK3510 Fuel Heater #2
I'll put my two cents in.
Look at the cost of a heater, the time to install it, the cost of electricity and how many hours you spend operating in below zero temps.
I would run number 1 fuel. That's what it is made for.
/ CK3510 Fuel Heater #3
Most gas stations that sell diesel fuel switch to a winter blend around October
The fuel heater isn’t something that runs off the tractor while it’s running?
/ CK3510 Fuel Heater #6
Yes there is one on the tractor when it is running. It's not going to start if the fuel is gelled.
An axillary heater is an option to keep the fuel from gelling while parked outside.
Anyone have the part number for the heater on the tractor? It ran for 5 minutes or so before it would die.
/ CK3510 Fuel Heater #8
Power service 911 if fuel is gelled
/ CK3510 Fuel Heater #9
I don't think the heater is your problem. Pull the filter and check it first. Make sure the fuel is flowing through.
/ CK3510 Fuel Heater #10
If it will run put power service 911 in the tank mix it up , start the tractor let it idle. I did 3 snow plow trucks 2 macks 1 ih never opened a hood
/ CK3510 Fuel Heater #11
Absolutely, as long as it starts.
If it doesn't start, check the filter.
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
Adams 5T HC (A63688)
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
IH International 1466 Tractor (A66285)
IH International...
PAN (A62613)
PAN (A62613)
