CK35 HST Pedal Problem
/ CK35 HST Pedal Problem #1
mgarner
HST pedal not returning to neutral position without help but ONLY when in high range. In other ranges it operates as it should. Anyone have a
possible solution??
/ CK35 HST Pedal Problem #2
Dunno if this helps..
What is different in my case is that the linkage is free when tractor is in medium or low range but will be really slow returning to center when in high. By slow I mean it takes 10 to 20 seconds if I let it return on its own which means I have to rock it back with my heel. I have gotten use to doing that and unless it is a simple fix I will leave it as is for now but would have some idea what is causing the problem
/ CK35 HST Pedal Problem #4
Did you read the entire thread? If it's still under warranty, have them replace the HST. If not, break out the check book. :(
Long out of warranty so will keep the check book in the desk and keep running it like it is. It has been that way for a few years now and maybe, since I am 87 now it will outlast me. Consider the problem as forgotten.
2022 Ford F-250 Knapheide Service Truck (A66736)
2022 Ford F-250...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
2014 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2014 Chevrolet...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
