CK30HST newbie questions
   / CK30HST newbie questions #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
Whats the best way to post picts?
I drove a 100 yds, then maybe 20 yds with park brake engaged. Did I fry anything? It works fine. I wish there was an audible alarm and may consider installing one. You dont feel a lag like a car would do. Easy to not see indicator in sunlight with sunglasses on.
Theres some tranny rattly noise at idle that goes away when clutch depressed---I dont hear it at higher rpm's. I suspect its a diesel resonance kinda like the tranny did when I had a 90 Dodge diesel 5 speed.
A slight knock/tick at idle from motor along with the usual diesel clacketa--wish I had a dealer closer to compare noises- however I really doubt theres a problem. It's easy to be critical of everything when it's new. /forums/images/graemlins/shocked.gif
Im going to make a light bar to mount to the ROPS--the headlights aren't enough for tractoring into the night. I think two forward and two rear pointing. Heck of a strong rig.
Moved boulders that were 1/10th above ground I used to have to mow around. The fuel is a pain to fill where its at, will need a fuel caddy set-up.
   / CK30HST newbie questions #2
<font color="orange"> Whats the best way to post picts? </font>
To post pics, they need to be under 100kb. A good resizing program I see mentioned alot is Irfanview (or something like that). Or, if you want, you could set up a gallery in the Photos section. You can have images up to 500kb in size with a maximum allowed space of 5MB.
To attach an image in the post, make sure I want to preview my post and/or attach a file is checked. Then you can upload the image from the preview screen.
Ignoramus asks: How do you know how many meg they are now and can they be shrunk?
I used a Cannon S50 digital camera /forums/images/graemlins/confused.gif
   / CK30HST newbie questions #4
When you transfer the photos to your computer, right click on them and click Properties. The file size will be given in the window that pops up.
   / CK30HST newbie questions #5
Link
This is the slickest way to reduce that I've seen so far.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
Steve
   / CK30HST newbie questions #6
Its funny you mention the parking brake concern today. I did the same thing while bush hogging my field today as well. I really could not tell the brake was on. Could not see the indicator in sunlight with the instrument cluster covered with seed and dust. Luckily I only went maybe 20 yards and had to back up. Noticed the tractor came to a complete quick stop instead of rollling forward some. I double check my self now the rest of the day.
   / CK30HST newbie questions #7
I've left mine on quite a few times. Fortunately, it doesn't seem to be much of a problem. It still works fine. No indicator light on my tractor. I usually notice when I push in the clutch and the tractor comes to an immediate stop.
   / CK30HST newbie questions #8
Mine makes a helluva racket with the brake on and won't move.
Pictures of new CK30hst being used at rec. property in Packwood, WA., 5 acres abuts National Forest above upper Cowlitz river .
Last pict. was the dealer, Ann the Tractorgal unloading new unit.
Heres Cracker on his new tractor. /forums/images/graemlins/cool.gif
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2014 Ag Spray Schaben Sidedresser (A52128)
2014 Ag Spray...
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
10' Feed Bunk (A50515)
