CK30HST newbie questions
   / CK30HST newbie questions
The President was so impressed with my Kioti, he invited me to Capitol Hill.... /forums/images/graemlins/shocked.gif
   / CK30HST newbie questions #12
The new Kioti looks great! /forums/images/graemlins/cool.gif
   / CK30HST newbie questions #13
Congratulations!!!! on the new tractor!!! Looking good.
Mine does has the same sort of rattle at idle that goes away when I push in the clutch. All seems to work just fine. 30 hours now. For fueling, I use a large funnel with a screen in it. I saw another post with a filter type funnel; but don't remember where. I use two 5 gallon containers and only put 4 gal in each. FYI you probably will have more fuel in the tank than you think; I overfilled the first time. /forums/images/graemlins/frown.gif fuel gauge is not linear. And, I also drove with the parking brake on a couple of times before I realized it was on; I've gotten into a routine and haven't done it since. I don't think you did any damage.
A CK30 HST is a good thing /forums/images/graemlins/cool.gif
Nice property - makes me home sick /forums/images/graemlins/wink.gif
Hey Rick, Next time you start it up cold let me know if you hear a faint tick/ knock in the background amid the diesel clatter in the engine area. That noise didn't change with clutch in. I don't think it a "death noise"---just curious.
I was doing most of my work with ear muffs on initially when "new" (less than 5 hrs) then started it up this am and was listening unmuffled.
Didnt hear it so much with engine sped up.
I didn't "baby" the motor too much but didnt abuse it either---varied speeds occasionally and kept between 1900-2200 working and not idling for prolonged periods.
Mower found an old loggers cable and bogged the motor way down as belt squealed---I pushed clutch in and stopped to examine as soon as I realized. /forums/images/graemlins/shocked.gif
Heres the tractor that works great but is just undersized to mow 3 plus acres regularly so now it just gets the smaller spots after Kioti went to town...
   / CK30HST newbie questions #16
</font><font color="blue" class="small">( How do you know how many meg they are now and can they be shrunk? )</font>
Right click on a picture, then select "properties" and you'll see what size it is. I've used different ways to resize pictures, but the one described in this post is the best I've found so far.
   / CK30HST newbie questions #17
I haven't had that brake problem with my CK30hst. It's a wet brake, so you should be OK.
My CK has 20 hours. I noticed the same rattling noise just like you along with the engine noise at idle. My dealer said it's normal.
The fuel fill isn't the greatest. When mine reads 1/4 tank, it will take five gallons. I use a big funnel with a screen.
   / CK30HST newbie questions #18
That low idle "tick" is normal for that engine. No worries.
I'm not sure you're pushing the brakes down hard enough before engaging the lock. On my CK20HST, if I leave the brakes on hard, it hits the pressure relief valve and I'm not going anywhere until I release the brake. The brakes can be engaged at different pressures. Make sure you push as hard as possible on both pedals and then engage the lock lever. If this doesn't keep you from knowing it's on with movement, you may need to adjust the brakes some.
John
2016 CATERPILLAR 236D SKID STEER (A52709)
2016 CATERPILLAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2022 Behnke Trailer (A55973)
2022 Behnke...
AEREATOR (A58214)
AEREATOR (A58214)
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
CASE TR340 SKID STEER (A52709)
CASE TR340 SKID...
