CK30HST difficult to shift from Low/Mid/High
   / CK30HST difficult to shift from Low/Mid/High #21
We run through quite a few tractors and they are all New and tight. If we have trouble getting one to change ranges, just hold pressure toward that range and barely push on the hydro pedal, it'll pop right in and not grind.
KO
   / CK30HST difficult to shift from Low/Mid/High #22
Personally i would rather see them too tight then too loose..... A little stiff will keep you from shifting by accident... atleast that is they way i think of it.... they do loosen up over time though.... once the paint gets worn though..
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
2392 (A60432)
2392 (A60432)
