CK30 turns over but won't start. Help
   / CK30 turns over but won't start. Help #1
Bogey5
I have a CK30 with only 200 hours. Its been about a month since I used it and when I first started it, no problem, let it warm up 5 minutes turned it off, then it wouldn't start. Just turns over. Thought might be air in fuel lines. Cranked it over with fuel switch in "air" mode, still not firing up. Fuel pump is pumping and fuel return lines have flow but when I removed lines from injectors, no flow when turning it over. Not sure why there is no flow through the metal lines. Am I missing something? Is there a shut off switch prior to the injector lines? Any help would be really appreciated.
   / CK30 turns over but won't start. Help #2
Could be a bad fuel shut off solenoid. Hopefully it's not the dreaded injection pump issue others have had, try doing a search on injection pump.
The fuel filter is cheap, you could try changing that.
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
John Deere 6110M (A53317)
John Deere 6110M...
207270 (A52708)
207270 (A52708)
2005 John Deere 7320 (A60462)
2005 John Deere...
