CK30 Rust under grab handles
/ CK30 Rust under grab handles #1
Alien
Elite Member
Grantham, South East Queensland
Kioti CK30 HST
I removed my grab handles one day just to put a layer of polish on the guard even though my little panther sits in the shed 90% of the time. Well, I got a shock! Underneath the handles rust had set in quite badly. It seems the nut that is moulded into the handle is of low quality and had rusted so bad it had spread to the mudguard and was bubbling the paint up.
I had to remove the rust and treat the area with cold gal paint and when dry I used a sealant under the handle to stop the intrusion of any water. I then used a nickle based anti seize lube to smear the threads of the bolts before I refitted the handles.
I suggest you remove your grabhandles and check this area.
Photo 1. The Hand grab.
Photo 2. The sealant can be seen around the edge if you look close.
Photo 3. The bolt head under the guard.
/ CK30 Rust under grab handles #3
So just came back in from moving fence wire from the shop to the new fence area behind the barn with the tractor. Did have my first look ever in over 3 years and the bolts looked good, no sign of rust. :thumbsup:
Hope so. Mine looked good too until I took the bolt out. It was a shock. As I said my 30 lives in the shed most of the time. We have a good climate here and rust is not usually a problem. The bolts are fine. It's the nuts embedded in the handle that are the problem. They start it off.
Doug
(2) 26X12.00-12 TIRES W/ 5 LUG RIMS (A64280)
(2) 26X12.00-12...
UNUSED WOLVERINE PT-16-01C 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2018 International LT Automatic Day Cab (A62613)
2018 International...
Ford F-450 (A63689)
Ford F-450 (A63689)
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
