CK30 PTO
/ CK30 PTO #1
cag
Platinum Member
Ottawa. Ontario, Canada
Grizzly 660 Kioti DK45SE Cab
In the past there was discussions regarding the rear PTO,I was left with the impression that.... The CK had 540rpm, and 1000 rpm was an option, to my surprise I pull the lever to a 1000 and it work's /forums/images/graemlins/shocked.gif did I miss something /forums/images/graemlins/confused.gif....cag
/ CK30 PTO #2
my ck 30 hst came with it. I know the mid pto is optional. Not sure if I will ever use the 1000rpm pto /forums/images/graemlins/grin.gif
aloha
joe
/ CK30 PTO #3
cag, I believe this was discussed some time ago and one of the dealers chimed on the subject. If I remeber, all or most of the CK30's (including mine), have this option, but there is a stop that will prevent engaging on some tractors. This is how my tractor is set up. Apparently there are some european implements designed for 1000 rpm's. I'm sure a dealer will jump in here and clarify.
/ CK30 PTO #4
CAG
My CK30 HST setup is exactly as HODAK described it. There is a stop which can be removed with a single screw or bolt (after gaining access to the lower part of the fender). It prevents the lever from going to the rear and engaging the 1000 RPM position. Yours my have been delivered with the stop removed. Since I don't have any attachments which could require that speed and diesels run better at higher RPM's I am not going to remove it.
Al
/ CK30 PTO #5
I like to run my RFM and Rear snowblower at 1000 rpms at a slower engine speed so it's quieter with the RFM and slower in reverse with the Snow blower.
/ CK30 PTO
Bob when running the snow blower at slower engine speed, at 1000 rpm did you ever encounter the engine bogging down...cag
/ CK30 PTO #7
When mowing, if I get in particularly tall grass, the exhaust will puff some black. But, I haven't run into snow that has done it yet. I think I've done about 18" of new snow max so far. It seems like slowing down the speed of the tractor, helps out in terms of the volume of snow that gets shoved in. My reverse gear is a little fast for my liking. I think if the snow was very heavy and deep it would start to bog down. But, I suspect this would happen at 540 at full speed also.
I try to keep an eye on it so I don't bog it down too bad.
/ CK30 PTO
Bob having hst, I'll have in my view better speed control by easing up on the hst peddle, I'm looking forward to the experience with both 540 and 1000, and like you, I'll keep an eye on and ease up if the engine bog's down, thank's for the input...cag
/ CK30 PTO #9
What engine RPM do you need to run to get an equivalent PTO RPM. I imagine you would have to be pretty careful about over revving your implements.
/ CK30 PTO #10
I'm going to do this from memory so take it with a grain of salt. I think the 540 speed is about 2650 rpms. When running the 1000 pto, I run the engine at about 1300 rpms. It seems to work fine and seldom bogs down. I would think if I forgot and ran the 1000 pto at much more than 1500 rpms I would start to overspeed and overheat the gear box or even worse, break the rotating parts.
/ CK30 PTO #11
I would not recommend any one to run a 540 implement in 1000rpm
I understand that you may be keeping that implement a the proper speed, But you will be doing damage to the tractor....The tractor RPM's are what helps keep the tractor running at the proper temp. by lugging the tractor the fan is not spinning as fast as you need to keep the engine and hydraulics cool, you will end up creating more heat and breaking down the oils faster.
If you still choose to run pay very close to the temp.
Just my opinion!
/ CK30 PTO #12
I definitely agree with Wallace. Seems like you would be lugging the engine more than you think. This can't be good. I would also be concerned with the implement speed. A few hundred RPM's over what the gearbox is designed for and look out! My $.02.
/ CK30 PTO #13
I agree with wallace and hodak. Brush hogging or snowblowing is hard work and running the engine at 1300 rpm is pretty low. Lugging an engine down, even a diesel, is not good. At that rpm, you're not letting the engine develop any power. If what you were running didn't require much pto hp, then the 1000 pto rpm might be a good choice but I don't think in your case.
Everyone has their own ideas. Just my opinion and info I've gathered from several diesel engine mechanics.
/ CK30 PTO #14
I agree with Wallace, with one exception - I have a PTO pump on my backhoe, and on occation I run the pump in the 1000rpm setting (when working with light stuff). I don't think this casues any damage(engine never bogs), however, I have found that it isn't really much of an advantage either. I don't need to run the engine up very far even in 540 PTO rpm mode, so at 1000 it's really just making the hoe jerkier than I'm able to deal with.
/ CK30 PTO #15
The reason I agree with Rick Wallace, is that the tractor is not designed to do tasks at such a low RPM as 1300. Not only does the fan run slower, but the oil is pumping more slowly also. 1300 is practically idle on these engines. A 1000 RPM implement would normally be used at a much higher engine speed, thus avoiding these possible problems. The damage will come over time, probably not right away.
John
/ CK30 PTO
Well guy's my first concern was not to bog the engine down, but if running the tractor at lower RPM causes insufficient cooling,I simply won't risk it, I have to admit do, running at a lower quiet RPM sounded pretty good , from the very happy CK30 owner /forums/images/graemlins/smile.gif...cag
/ CK30 PTO #17
It just dawned on me, DUH!, that I could run my alternator welder at the 1000 RPM PTO speed and forgo the gearbox. I could use a pully maybe a bit larger than the crank pully and achieve the same rpm for welding. On my Jeep that's about 1000 rpm. There wouldn't be much strain on anything since the tractor would be sitting still and I could run the engine at a lower rpm with a larger pully.
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
HEAVYEQUIPMENT HOSES (A68842)
HEAVYEQUIPMENT...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
2027 . . (A67714)
2027 . . (A67714)
2016 Bomag BW90 AD-5 Tandem Vibratory Smooth Drum Roller (A66734)
2016 Bomag BW90...
