CK30 Injection Pump
/ CK30 Injection Pump #41
DSC03875.jpgDSC03858.jpgDSC03859.jpgSorry to tell you guys but the teeth in the pump gears are kaput! I had same problem @ 200 hrs Called dealer and was given cold shoulder as my tractor was a 2007 and warranty was up. Was told that for several years pump had a problem, Kioti knew but never fixed. Now they have new pump with better gears for $ 1076 + tax. Part # E5500-51015. Replaced pump and tractor runs fine. Took aproximatly 3 hrs had to remove intake manifold and hood. Took old pump apart and one gear had 3-4 teeth broken other two gears look ok. Anyone interested in used gears contact me @ triser@tampabay.rr.com.
/ CK30 Injection Pump #43
I have a ck25 and had pretty much identical problem, I removed the pump and had it rebuilt by bosh injector shop that I found locally. I was really fortunate it ended up costing less than $600 to rebuild
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2004 John Deere 693 Corn Head (A66285)
2004 John Deere...
2023 General XP 1000 Sport (A62679)
2023 General XP...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
