CK30 Injection Pump
/ CK30 Injection Pump #41
DSC03875.jpgDSC03858.jpgDSC03859.jpgSorry to tell you guys but the teeth in the pump gears are kaput! I had same problem @ 200 hrs Called dealer and was given cold shoulder as my tractor was a 2007 and warranty was up. Was told that for several years pump had a problem, Kioti knew but never fixed. Now they have new pump with better gears for $ 1076 + tax. Part # E5500-51015. Replaced pump and tractor runs fine. Took aproximatly 3 hrs had to remove intake manifold and hood. Took old pump apart and one gear had 3-4 teeth broken other two gears look ok. Anyone interested in used gears contact me @ triser@tampabay.rr.com.
/ CK30 Injection Pump #43
I have a ck25 and had pretty much identical problem, I removed the pump and had it rebuilt by bosh injector shop that I found locally. I was really fortunate it ended up costing less than $600 to rebuild
2008 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2008 MACK GRANITE...
Woodland Mills Sawmill (A65579)
Woodland Mills...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Generac Speedwash Pressure Washer (A65640)
Generac Speedwash...
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
