Mowing CK30 HST Belly mower removal
   / CK30 HST Belly mower removal #1
rk20033
N.E. Ohio
I need to remove the belly mower from my tractor. I unhooked the drive shaft and then 4 pins that hold it to the frame. It slides around nicely on the floor, but I can not seem to figure out how to get the gear box on the mower past the
framework on the tractor. I thought about jacking up the tractor but I thought there had to be a better way.
Thanks,
Vince
   / CK30 HST Belly mower removal #2
Do you have a FEL on the tractor? Use it to lift the front end by pushing the bucket into the ground. If not get a set of car ramps to drive the front end up on. You only need a couple of inches so don't have to drive it all the way up the ramps.
Faced the same dilema first time I took the mower off my ck20.
   / CK30 HST Belly mower removal #3
If it's like the CK20, it will come out much easier on one side than the other.
Ditto on what pilonidal said, we have also used 4x6's to get the front up a little.
KO
Thanks all for the help. I do have a fel, it did work great.
   / CK30 HST Belly mower removal #5
Hello Rk, Im curious what size belly mower your using with the ck30, how does it work as well? Matt
I have the 60". I got the tractor in October of last year, so I haven't used the belly mower as of yet. I will have to wait till spring to find out.
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59905)
2021 CHEVROLET LCF...
2011 JLG E400AJP MAN LIFT (A60429)
2011 JLG E400AJP...
