CK30 clutch issues
/ CK30 clutch issues #21
Thanks Dirtnut, im curious if you lifted the steel off a flat bed truck or a flat bed trailer.. I too have moved slabs of concrete 8 ' x 20" x 12", im guessing were about 12 cu ft of concrete at 150lbs per ft, probably in the 1800 lb area. That was only a foot off the ground or so with 3 people on my box blade, just to move it out of my barn area when i had a fire. With my 1000lb backhoe on the back, ive lifted 10 - 12 foot by 24 in oak logs on equipment trailers with little effort. The logger said the logs were in the 1500-1600 lb range. Its not something i like to haul over long distances though. I actually talked to my dealer and hes going to let me know when a used pair of forks come in, new ones are around 900, used he says are about half that. Im just going to use them for moving pellet pallets and if i have to manually off load 500lbs , so be it..
/ CK30 clutch issues #23
That is actually quite impressive off a flat bed truck, i will be lifting off a 18 ft dove tail equipment trailer, so its not nearly as high for lift off.
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
(10) Mini Ex Bushings (A60463)
(10) Mini Ex...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
