CK30 clutch issues
/ CK30 clutch issues #21
Thanks Dirtnut, im curious if you lifted the steel off a flat bed truck or a flat bed trailer.. I too have moved slabs of concrete 8 ' x 20" x 12", im guessing were about 12 cu ft of concrete at 150lbs per ft, probably in the 1800 lb area. That was only a foot off the ground or so with 3 people on my box blade, just to move it out of my barn area when i had a fire. With my 1000lb backhoe on the back, ive lifted 10 - 12 foot by 24 in oak logs on equipment trailers with little effort. The logger said the logs were in the 1500-1600 lb range. Its not something i like to haul over long distances though. I actually talked to my dealer and hes going to let me know when a used pair of forks come in, new ones are around 900, used he says are about half that. Im just going to use them for moving pellet pallets and if i have to manually off load 500lbs , so be it..
/ CK30 clutch issues #23
That is actually quite impressive off a flat bed truck, i will be lifting off a 18 ft dove tail equipment trailer, so its not nearly as high for lift off.
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
UNUSED WOLVERINE LL-12-78W-78" LAND LEVELER (A64281)
UNUSED WOLVERINE...
2024 JCB 35Z (A60462)
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
