CK2610HST glow plug light
/ CK2610HST glow plug light #1
Paul_1SG
Kioti CK2610
Hello all,
I purchased my CK2610HST May of 2020. The glow plug light on the dash has not worked since I purchased the tractor. It does not work when I turn the key backwards and hold or when I turn it forward to the first position. The tractor starts every time.
Can anyone with a newer CK2610 please describe how their glow plug light works with key in either direction.
Any help would be greatly appreciated.
/ CK2610HST glow plug light #2
I am not familiar with the dash on CK models but are you sure the glow plugs are working?
I also am not aware that it should come on in both directions with the key. I would think it is one or the other. Models with a glow plug timer usually will have a light and that comes on with key and turns off with glow plugs.
Manual ones usually has some other element that glows when energized. Hopefully someone with a CK model will chime in.
/ CK2610HST glow plug light #3
I have a CK2610HST. My glow plug light comes on when I turn the key to the right and goes off depending upon the ambient temperature. It also comes on when I turn the key to the left. Purchased new, worked the same since delivered.
Thank you guys for the replying. I just checked again tonight and the glow plug light still does not come on in either position. Does anyone know where the glow plug relay is?
Thanks again guys. I greatly appreciate the help.
/ CK2610HST glow plug light #5
Look under the right side of the dash above the brake pedal and make sure all the plugs are plugged together. My hour meter wire was unplugged from the factory. Might be somewhere else, but there are several on that side.
/ CK2610HST glow plug light #6
The glow plug relay is on the left side, if needed.
/ CK2610HST glow plug light #7
Hi Paul,
I have a 2018 and I believe there may be an ambient/coolant temp sensor in the circuit. Since it's been hot outside, I've noticed my glow plug light doesn't illuminate, but the engine fires off in an instant. When the temps are cold, the light is on for a short time, or longer if it's really cold and I turn the key to the left and hold it. I just searched my owners/operators manual and there's nothing about the light not coming on when it's warm.
Patrick
/ CK2610HST glow plug light #8
Is your dealer local to fix it?
Looking at the schematic, I do not see how the glow plug relay would affect the light indication on the dash, but maybe it's internal to the Preheater Controller seeing current flow to the glow plug relay coil. I would look above the glow plug relay (it's the one in photo with large red wire), located as stated on the left side just above the clutch pedal. I was going to say check that the connector shown is fully engaged, BUT it also controls fuel related components, so the tractor would not run.
I do love Kioti documentation- on page 12-71 they call the box 'Preheat Controller', then on page 12-73 it is now called the 'Safety Controller'. The box is making sure the coolant is less than 20 C/ 68 F to initiate the glow plug energization by picking up the glow plug relay via pin 12, and turns on the dash light via connector pin 11.
Seems like the box is working functionally on everything else, just not the glow plug light. I would check that the temperature sensor is fully connected (appears to be a three wire connector) but haven't a clue where it is. In the factory service manual page 12-11 it shows it on the block just above the alternator as posted above, but mine only has a allan type plug installed there. Gotta love it!!
For what it's worth, Toukow
/ CK2610HST glow plug light #9
Didn't mean to submit the above post, but oh, well.....I would do a quick check and put a finger on the glow plug relay and see if it clicks when turning the key on and temperature below 68 degrees indicating a light LED issue. Oh, I did find the temperature sender and it's located just underneath where the top radiator hose connects to the engine, on the right side of the block. Good hunting.....
Gentlemen,
Thank you all for the responses. I’ll follow up after this weekend when I get a chance to look at the tractor.
/ CK2610HST glow plug light #11
Operated the tractor a lot this past weekend moving gravel from creek bed to RV and vehicle parking area. 112'F Saturday and 108'F Sunday. No glow plug light except when key on instrument panel self test. Might be a few months before the glow plugs kick in.
Patrick
/ CK2610HST glow plug light #12
It's finally cooled off here, and the glow plug light is turning on again.
Patrick
It was 49 degrees outside this morning in south Georgia. I turned the key to the on position. The dash diagnostic lights came on and then off. However, the glow plug light stayed on for a few seconds longer. This leads me to believe the preheat system is temperature triggered.
I wanted to thank everyone for their input. I have been super busy with my first granddaughter this summer. I have not had much time to troubleshoot these days. The input you all have provided makes me feel confident that there is no issue other than south Georgia is too darn hot to trigger the preheat function. I’m greatful for all the knowledge and experience all of you offered.
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Unused 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Unused 10-16.5NHS...
429835 (A61166)
429835 (A61166)
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
Shamrock 10ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 10ft. S/A...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
