CK2610 Hydraulic Remote
/ CK2610 Hydraulic Remote #1
sailorman3
Newfoundland
Kioti CK3510
I want to install a hydraulic top link on my tractor. Can I plug it into my backhoe remote or do I need a different remote. Thanks!
/ CK2610 Hydraulic Remote #2
How is your backhoe set up? When you remove it do you loop 2 hoses together?
/ CK2610 Hydraulic Remote #4
If the rear remote has a control lever beside the seat, then yes you can use it for other hydraulic attachments.
/ CK2610 Hydraulic Remote #5
Yep, if you have "in and out" ports for the remotes and a valve to control them, you're set to go! I just did the same type of setup. I have 2 pair of remotes, so a side link will be put on shortly also.
Here is a link to a supplier with great prices:
and for their hose kits... best price out there, great quality!
/ CK2610 Hydraulic Remote #6
Make sure you hook it to a spring centered valve. If you don't there's risk of not recentering the valve causing available power to drop and overheating the fluid.
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
Kiefer Built Livestock Trailer (A66285)
Kiefer Built...
2022 EZ-GO ELITE...
Adams 5T HC (A63688)
2022 EZ-GO ELITE...
