CK2610 Hydraulic Remote
/ CK2610 Hydraulic Remote #1
sailorman3
Newfoundland
Kioti CK3510
I want to install a hydraulic top link on my tractor. Can I plug it into my backhoe remote or do I need a different remote. Thanks!
/ CK2610 Hydraulic Remote #2
How is your backhoe set up? When you remove it do you loop 2 hoses together?
/ CK2610 Hydraulic Remote #4
If the rear remote has a control lever beside the seat, then yes you can use it for other hydraulic attachments.
/ CK2610 Hydraulic Remote #5
Yep, if you have "in and out" ports for the remotes and a valve to control them, you're set to go! I just did the same type of setup. I have 2 pair of remotes, so a side link will be put on shortly also.
Here is a link to a supplier with great prices:
and for their hose kits... best price out there, great quality!
/ CK2610 Hydraulic Remote #6
Make sure you hook it to a spring centered valve. If you don't there's risk of not recentering the valve causing available power to drop and overheating the fluid.
