Ck20s Power steering issue! Little help please!
   / Ck20s Power steering issue! Little help please! #1
Baymen12
Canada
Ck20s
Every now and then my power steering quits. Everything else works fine(loader as well). Hydro fluid looks good. When checking dipstick should it be seated or just inserted? Anything else I can look at?
   / Ck20s Power steering issue! Little help please! #2
The ck20 has a single gear pump that flows the oil through a priority valve. Priority is supposed send a specific amount of oil to the steering and remainder to the load & 3pt. The regulator stem or spring in that valve might be sticking & dumping all flow to the loader circuit.
That definetly sounds right. Can this be taken apart and cleaned or do you just replace?
Again thanks for the help.
Steve
   / Ck20s Power steering issue! Little help please! #4
Steve
You can look at it and if you don't find anything obvious [piece of hose, dirt ect] from experience replace it. I don't know what valve is used on the 20 but most are cartridge style and the cartridge can be easily replaced without messing with the body. CJ
Enclosed Service Truck (A55788)
Enclosed Service...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
