Ck20s Power steering issue! Little help please!
   / Ck20s Power steering issue! Little help please! #1
Baymen12
Canada
Ck20s
Every now and then my power steering quits. Everything else works fine(loader as well). Hydro fluid looks good. When checking dipstick should it be seated or just inserted? Anything else I can look at?
   / Ck20s Power steering issue! Little help please! #2
The ck20 has a single gear pump that flows the oil through a priority valve. Priority is supposed send a specific amount of oil to the steering and remainder to the load & 3pt. The regulator stem or spring in that valve might be sticking & dumping all flow to the loader circuit.
That definetly sounds right. Can this be taken apart and cleaned or do you just replace?
Again thanks for the help.
Steve
   / Ck20s Power steering issue! Little help please! #4
Steve
You can look at it and if you don't find anything obvious [piece of hose, dirt ect] from experience replace it. I don't know what valve is used on the 20 but most are cartridge style and the cartridge can be easily replaced without messing with the body. CJ
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
202482 (A54757)
202482 (A54757)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2010 Ford F-150 Single Cab Pickup Truck (A55973)
2010 Ford F-150...
16001 (A55853)
16001 (A55853)
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
