CK20s front diff problem
/ CK20s front diff problem #11
Was the sacrificial pin being sheared often so the fix was to turn the shaft around? Was the owner always in 4x4 on pavement and got tired of replacing the pin? Who knows?
All great questions and unfortunately will never likely know. Guess this is the gamble I took by buying used. No word back from the Kioti dealership yet...
After falling victim to the 遡ioti hack parts delay, finally the tractor is back together and working. The shop replaced the bevel gear and bevel shaft (ring and pinion) two bearings and various shims and seals. Unfortunately we will never know why this happened, I installed the drive shaft the correct way so hopefully my first kioti experience gets better from here....
/ CK20s front diff problem #14
Sounds like an interesting situation, did you get any pictures? Glad you got it back together right, I'm sure you saved a couple hours of shop time by striping it down yourself.
2014 FREIGHTLINER CASCADIA 6X2 MID ROOF SLEEPER TRUCK (A59908)
2014 FREIGHTLINER...
2007 Avanti 36 Boat with Tri-Axle Boat Trailer (A59231)
2007 Avanti 36...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 1.5 Ton Crane Utility Truck (A59230)
2005 Mitsubishi...
2012 PETERBILT 386 SLEEPER (A59906)
2012 PETERBILT 386...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
