CK20 Trailer
/ CK20 Trailer #21
It's true! In CA if you pull ANY trailer rated over 10K you must have a class A and the other great thing out here is if you have a truck with a flat bed you must have a CA number! /forums/images/graemlins/confused.gif
/ CK20 Trailer #22
</font><font color="blue" class="small">( It's true! In CA if you pull ANY trailer rated over 10K you must have a class A and the other great thing out here is if you have a truck with a flat bed you must have a CA number! )</font>
Are you sure that's not anything over 25,999? Here in Florida, the whole rig can weigh under 26,000 you only need a class D CDL.
John
/ CK20 Trailer #23
I have checked with a PA (Even though I live in Ohio) state trooper and he did not have a problem with it. There is a chain with lever binder in all 4 corners (I did not trust straps with the weight of this load. I used to haul forklifts (under 10k) for a guy who would have killed me if I ever used a strap, insisted forks be facing backwards, chains on all 4 corners). The only problems that I could possibly encounter is the bucket not being secured down and with the BH on I secure the hoe with the transport pins.
I only have brakes on the front axle which in extreme emergency braking might not be enough. (Not counting when I go to PA where they require brakes on all axles).
Kurt
/ CK20 Trailer #24
I'm talking about the trailer.You could use a honda civic with a trailer hitch,If your trailer # is over 10k you need a CDL class A
/ CK20 Trailer #25
Here in Cali, if the TRAILER you are pulling is rated OVER 10,000 lbs. you need a "class A". I know a guy who was using a 12,000 lb. trailer to haul equipment and got a ticket for not having a class A, he has since down sized to a 10,000.
PALLET OF LILLISTON ROLLING COULTER PARTS (A63745)
PALLET OF...
2005 FORD E-350 S/A MOBILE CONCEPTS CUSTOM CONVERSION (A59910)
2005 FORD E-350...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
John Deere 145 Lawn Mower (A63116)
John Deere 145...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
