CK Identify these empty lever slots
/ CK Identify these empty lever slots #1
TracerRound
Taylorsville, North Carolina
Kioti CK3510HST
There are two empty slots on my ~2019 CK3510 between the 3 point raise/lower lever and the cup holder. Assuming these are for addons, anyone know what those would be for? I didn't see anything in the workshop manual but its also like 400 pages.
/ CK Identify these empty lever slots #2
Those are for the levers that controls the remotes at the back. The remotes are two hydraulic valves that you would have on the rear of the tractor with quick disconnects so you could use those for an hydraulic top link, dump trailer, etc.
Thank you! I am actually adding a Summit Hydraulic rear and 3rd function remotes and was debating on mounting the electronic switch box between the two slots instead of the metal assembly off the ROPS. Wasn't thinking the factory rear control would be levers, assumed electronic too.
/ CK Identify these empty lever slots #4
Levers allow for feathering of the controls, while electronic (without going with the super expensive proportional controls) as just On/Off. No control on how fast/flow the cylinder moves.
/ CK Identify these empty lever slots #5
The Kioti version is quite well priced as well if haven’t already gone ahead with the summit rear. It was 5-600 dollars for two rear remotes if I recall.
/ CK Identify these empty lever slots #6
You can also choose the type. Both with detents, both with no detents, or one of each. No way would I put up with electric controls, they're just nasty to use.
CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
CASE 590 SUPER M...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2001 Nissan Frontier Pickup Truck (A62613)
2001 Nissan...
2022 EZ-GO ELITE...
50in 3 Point Hitch Tiller (A65579)
50in 3 Point Hitch...
