CK 35 HST - 2nd rear remote with Float feature
   / CK 35 HST - 2nd rear remote with Float feature #1
powerscol
SW Colorado
CT 235
Folks - looking for some help. Does anyone have the part number for the second rear remote kit that has the float option for the CK 35 HST. I believe Kioti offered this in the past, while Bobcat did not. I have the Bobcat Clone to the CK 35 HST.
I am running some hay equipment that needs to be in float while in operation, and my current rear remote ( Bobcat part number 7150492) will not do this.
Thanks
   / CK 35 HST - 2nd rear remote with Float feature #2
I don't believe Kioti offers a second remote with a float. Could be wrong, and I know its been argued over before. You might be able to jerry rig something, but someone else will have to help there. As far as I know however, Kioti does not offer a float option for the CK remotes. A call up to Michigan Iron and Equipment might help, as they have a heck of a lot of Kioti parts.
   / CK 35 HST - 2nd rear remote with Float feature #4
Davrow had one put on his CK 27.
Photos can be seen here post # 14 http://www.tractorbynet.com/forums/bobcat-tractors/327499-float-action-rear-remotes-2.html
I was hoping to find one that fit the CK 35.
Thanks for any help.
The other option is some sort of system ( electric solenoid attachment) to allow the second remote to float between the lines.
I stand corrected. If it works on the CK27, it should fit the 35, same hydraulics as far as I know, and I think the only difference is the HP.
While I can get into the online Bobcat Parts book, Kioti does not have this on their web site. I called several Kioti dealers in states near me, and none seem to be able to help...indicating it does not show up in their current parts book, even for the CK 27. Hoping someone might have an old parts book around that might have a moment to look it up.
Thanks for any help
   / CK 35 HST - 2nd rear remote with Float feature #6
This has been brought up several times, but to the best of my knowledge, Kioti does not offer a rear remote valve with float.
   / CK 35 HST - 2nd rear remote with Float feature #7
What is the hay equipment you need to float?
   / CK 35 HST - 2nd rear remote with Float feature #8
   / CK 35 HST - 2nd rear remote with Float feature #9
Sorry, no part number but yes, I had a float position on the second remote of my CK30, installed by my dealer using Kioti parts.
   / CK 35 HST - 2nd rear remote with Float feature #10
James, you know better,:confused: CKs only. http://www.tractorbynet.com/forums/...19789439-float-action-rear-remotes-levers-jpg
I personally installed Davrow's top & tilt set. One of the control valves for the rear remotes has the float function. :thumbsup: His rear remotes were added by his dealer using Kioti parts. ;)
True, but this seems to be the only case, and no one knows the part number. I know there is no mention of a float in any of the Kioti literature I have seen online or paper, and no mention of it in my manual. I know MIE has a good reputation and parts lists and inventory. Call them and see what they say. davrow could give some help here too. Otherwise you may have to fix something yourself, Brian can probably help with that.
2015 FREIGHTLINER CASCADIA SLEEPER (A57880)
2015 FREIGHTLINER...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2025 Mower King SSAB72 (A56469)
2025 Mower King...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2017 Ford F150 (A55973)
2017 Ford F150...
2026 Industrias America 227T (A56469)
2026 Industrias...
