CK 35 HST - 2nd rear remote with Float feature
   / CK 35 HST - 2nd rear remote with Float feature #11
Try this number
008266 detent float valve
Thanks - I assume this is a Kioti number.
Everyone has been great, so I will get back with the information I get. Several great folks are checking into this.
I Google it and talked with Michigan Iron - That number is for the complete unit with both remotes. They said that the second remote kit part number is 322027 for the CK 35 HST and has the float option on it. However when I looked up that part there is no mention of the float feature. Has anyone installed this valve, and does it have the float at the bottom location?
As for the float I am adding a hyd cylinder to my IH 1300 mower and need float on the cylinder in the down position (double acting cylinder) I am also looking into either a drum or disk mower and they both say to put into float in the operation position.
   / CK 35 HST - 2nd rear remote with Float feature #14
thanks for the update, least maybe you have the part number now. I would ask about returns to michigan iron, if you recieved it and was not float. I converted my 1300 to hydraulic lift and really like it, the kubota i was using when i did that, didn't have float so I had to build the linkage to float.
Do you have any pictures of your conversion and especially how you fabricated the float linkage?
   / CK 35 HST - 2nd rear remote with Float feature #16
The Part numbers from the Dealer invoice for my Valves are as follows: New Last Fall 2014
KI322026 Kioti Valve Kit CK 20 / 35
KI322027 Kioti Double Acting Valve Kit CK 20 / 35
I assume the Double Acting Kit is the valve with float?? Hope this helps.
   / CK 35 HST - 2nd rear remote with Float feature #17
In 2007, I added both rear remotes to my CK30hst. Neither of the valves had a float position. I'll check for the part numbers and see if one is able to be converted to a float valve.
   / CK 35 HST - 2nd rear remote with Float feature #18
Here are a couple of part numbers.
Item numbers are:
KIQ-322027 convert single valve to double
KIQ-322026 Rear aux hyd valve kit
These are the part numbers off the customers invoice that has the 2nd valve with the float function for a Kioti CK27.
Great Information. Now to find out if the KQI 322027 will fit my Bobcat block.
Thanks for the help.
   / CK 35 HST - 2nd rear remote with Float feature #20
Prior to the remote valves, I used to have an OEM Kioti "hose kit", as it was called, to power my bh. It mounted in the exact same place as the remote valves. I had saved the hose kit after installing the remotes. This past Summer, a member who had a CT225, was looking for this hose kit to save money as he didn't need the function of a valve. Long story short, I sold him my hose kit and it mounted and worked fine. So I believe the Kioti remotes would fit also. MEI is also good on returns if something isn't right. You'd just have to pay return shipping if for some reason it's not what you want.
Sno Biz Shaved Ice Stand (A56469)
Sno Biz Shaved Ice...
2016 Ford F-450 12ft Utility Flatbed Truck (A55852)
2016 Ford F-450...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
3pt 3 Row Cultivator (A53317)
3pt 3 Row...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
