Circle Cub (4 digit) Restoration
   / Circle Cub (4 digit) Restoration
Straightened out the tie rods and fixed all that.
Repaired the transmission and installed new bearings/seals.
Repaired the oil filter bolt and made a new top for it & added an o-ring for better sealing.
Cleaned the light lenses with oven cleaner to get the rust off, found nothing that works better. Cleaned the rest of the lights and primed them. Also made 2 new locking nuts.
Took .004" off the flywheel and turned the starter ring around.
Cleaned the carb and made a new idle tube for it. It was broke off and missing.
Had the hood sandblasted before priming.
Found the circle C decals under old paint.
Repaired/cleaned the dash.
Made a new lid & front for the battery box.
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2002 International 9200i Truck (A51039)
2002 International...
16ft Trailer (A50322)
