Chugging Kubota B3000 CAB
   / Chugging Kubota B3000 CAB #1
l3400kubota
Charlton, NY
Kubota L3400
I have a new Kubota B3000 CAB and it blows white smoke and chuggs for the first 15 seconds after starting. Any ideas?
   / Chugging Kubota B3000 CAB #2
How is your radiator water holding up. White smoke usually indicates water in the combustion chamber. You may have a blown head gasket. Sometimes they only leak when the engine cools off and then water seeps into the cylinder walls to lay on top of the piston. Some of this will usually find its way to the oil pan. Check your oil, is it turning milky?
   / Chugging Kubota B3000 CAB #3
It's cold out, sounds normal to me. Is this your first diesel?
   / Chugging Kubota B3000 CAB #5
I have a B-3000 Kubota also. This sounds normal to me too ! Use the glow plug.... but also try leaving your glow plug on 'after it starts up', by turning the ignition key until the little orange indicator light comes on, that smooths mine out.
I plug in the block heater below freezing also.
   / Chugging Kubota B3000 CAB #6
You can cycle it twice when cold before cranking to help with this issue.
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
2014 Yamaha YRDEX4 Golf Cart (A56859)
2014 Yamaha YRDEX4...
2171 (A58376)
2171 (A58376)
2359 (A58376)
2359 (A58376)
2019 Toro Greensmaster 3150-Q Commercial Reel Mower (A56857)
2019 Toro...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
