Ballast Choices for liqiud ballast in rear tires?
   / Choices for liqiud ballast in rear tires? #41
If anyone is still following this thread;
After much careful cogitation I come back to good old anti freeze.
Here's what I am thinking about doing.
A pump from Grainger (for those with catalog 396 the pumps are at the bottom of page 3183, their stock numbers 1P579, 1P580 and 4RU63, the cheapest at $45). I am leaning towards the cheapest as I only plan to do this once unless something terrible happens to one of my rear tires).
My tires at 75% full apparently hold 47 or 48 gallons of water. A 4 to 1 mixture of anti freeze should protect the tires down to 10 degrees above (the coldest I have ever recorded here in 28 winters is 17 degrees above so 10 should be enough) I would need 12 gallons of anti freeeze per tire. Anti freeze is about $10/gal and maybe I can get a discount if I buy 24 gallons) so about $240.
The NAPA gadget should be $10 or less to adapt garden hose to the tire valve.
So; about $300 should do the job.
Any thoughts about this approach?
I have never attempted this particular task before so any advice and/or hints will be gratefully received.
Thanks in advance;
David Jackson
   / Choices for liqiud ballast in rear tires? #42
Looks like you're on the right track David. Sorry I couldn't remember exactly where I saw the gadget. But the Grainger and Napa set up should work. You might check if you can get away with less anti-freeze. If I'm not mistaken, even partially frozen (shlush) tires are OK as long as they don't freeze solid. But then again at 10 bucks a gallon, that's not too bad.
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
15200 (A56857)
15200 (A56857)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
