Comparison Choices, Choices, Too Many Choices
   / Choices, Choices, Too Many Choices
What's the feeling here about Mahindra? They seem to have some special promos and discounts right now, but I don't know much about their machines versus the others.
   / Choices, Choices, Too Many Choices #32
Not sure they've established a reputation for quality yet.
   / Choices, Choices, Too Many Choices #33
I looked at Mahindra back in 2008 before I bought my first Kioti tractor.Not many Mahindra dealers around my neck of the woods.More kioti dealers (3) have sprung up around here in the last 3 years.
   / Choices, Choices, Too Many Choices #34
The Max 26XL from Mahindra is made by Mitsibushi Heavy Equipment in Japan. Girlwhowantstractor has one and she says the loader shows made by Ansung in S. Korea but all the other stickers say made in Japan by Mitsibushi. The Max24 should be the same. Mitsubishi is great manufacturer.
The eMax series is made by TYM for Mahindra so you can buy the eMax from Mahindra or the RK24 from Rural King or a TYM branded model but you are still getting TYM Product.
I believe Daedong (Kioti parent) is making the motors for the eMax and Mitsibushi makes their own motors for the Max 24/Max 26XL.
Someone please correct me if I'm wrong on the motors. Thanks.
The dealer I was at also sells Husqy and Simplicity riders as well as Grasshopper ZTRs, Stihl tools and a few other brands. Seems like an odd mix.
   / Choices, Choices, Too Many Choices #36
There are only two eMax models currently. The eMax 20 engine is made by Yanmar. Not sure about the eMax 22.
And yes, the Max 26XL seems to be a Mitsubishi tractor except for the loader. I have no concerns with quality because of Mitsubishi's reputation.
If folks are interested, I can peek under the hoods at my dealer this week. :)
   / Choices, Choices, Too Many Choices #37
One thing I noticed today that I wasn't really expecting to see was rust. Every machine, all the colors. And in places I thought should not show it, like hydraulic fittings and ram cylinders. These were all brand new machines too. I'm terrible at caring for stuff, so if it's rusting in their lots, what can I expect in a few years?
Has anybody considered spraying some kind of clearcoat sealant on these areas when you get them?
I would not accept rust on the cylinders (the shiny stainless steel part). These should be made of an extremely high-grade steel that will not rust.
SURFACE rust on the body, well, that seems to come with the territory. Buy some Fluid Film and keep a can near where you store your tractor. Spray everywhere you see rust, the ball joints on your 3PH, and basically every part that moves. Spray all the bolts and attachment points on your implements; makes hook-ups a bit easier.
Definitely spray all of your hydraulic cylinders immediately, and work them in and out. Yes, they are not supposed to rust but are so important they deserve a little extra protection and lubrication.
This is fun and easy, so even if you don't normally enjoy "caring for stuff" you can do this.
   / Choices, Choices, Too Many Choices #38
Owning a Mitsubishi tractor i.e the Max26XL Shuttle, I is a decent quality Tractor, but in general, there as some rough edges and observable cost cutting. I feel at 80-85% of the cost of the top brands and having good specs for it's size class, the tractor is a good value for the use I put it to.
   / Choices, Choices, Too Many Choices #39
Owning a Mitsubishi tractor i.e the Max26XL Shuttle, I is a decent quality Tractor, but in general, there as some rough edges and observable cost cutting. I feel at 80-85% of the cost of the Top brands and having good specs for it's size call, the tractor is a good value for the use I put it to.
I stay out of the tractor wars, but am curious, having seen this mentioned a few times: what are the "rough edges" and "cost cutting" you have observed? Thanks!
   / Choices, Choices, Too Many Choices #40
The loader valve sucks. The brakes suck. The manual transmission versions suck. At least that’s my experience with Mahindra.
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
John Deere 2155 (A53317)
John Deere 2155...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2012 PJFS25 Goose Neck Trailer (A55973)
2012 PJFS25 Goose...
