Comparison Choices, Choices, Too Many Choices
   / Choices, Choices, Too Many Choices #41
I stay out of the tractor wars, but am curious, having seen this mentioned a few times: what are the "rough edges" and "cost cutting" you have observed? Thanks!
https://www.tractorbynet.com/forums...-100-hrs-service-look-over.html?highlight=100
https://www.tractorbynet.com/forums...-mahindra-max28xl-shuttle.html?highlight=28XL
Paint, plastics, labels decals, electrics, fasteners, ergonomics, smoothness are a little bit to a lot better on most Kubota's or other premium tractors, but by no means are the Mitsubishi tractors junk. The 8 x 8 shuttle is a gem compared to most other tractor manual transmissions and the 3 Pt hitch is stronger than a lot of larger tractors.
PS I have 334 hours to date. Only one trip for dealer service/warrantee.
I can't exactly explain it, but standing next to a 1025R and a Max 24 within an hour of each other there was just a sense that one was somewhat less than the other. It may only have been appearance things that made no functional difference. That may not make sense to some people, but if the pricing is close enough, I'd end up going green. And I'm not partial to green. I have some issues with the company, but at the $15-20K range, I need to be comfortable and 'feel' the difference.
That said, we all know that JD intentionally makes parts to odd specs so they're less available from third parties. There are a lot of parts you can get ONLY from them. Since these Max models seem to be made by TYM and the engines by others, can y'all tell me if the TYM and engine parts are more generally available from third party suppliers?
   / Choices, Choices, Too Many Choices #45
PS I have 334 hours n trhttps://www.tractorbynet.com/forums/asset.php?fid=488045&uid=19607&d=1525749400actor to date. Only one trip for dealer service/warrantee.
Thanks for the links! I really appreciate your thoughtful comments, especially since you're an engineer. I feel that all of your points are well taken, and it seems you are impressed with the tractor overall. Everyone says the loader valve lacks finesse and I can second that. However, with practice it's "smooth enough" for my use. I can see that someone with finer tastes in tractors would expect a cushion valve or some such refinement. As far as some of your other points about paint and such, yours was I believe a 2013; I wonder if you've checked out the more current models? Some of the older models had components manufactured in India or by various other manufacturers; mine (2018) seems all Mitsubishi and I'm not seeing some of the defects you point out. Also I was all over the tractor with a magnet :) and found no aluminum. Interesting discussion, and I am always wanting to learn more about the fine points on these tractors. However, the important thing is it starts up easy, runs smooth, and does everything I ask of it. :)
   / Choices, Choices, Too Many Choices #46
Appearances can be deceiving..... :) Bring a magnet with you next time.
   / Choices, Choices, Too Many Choices #47
Hmmm, mine seem fine. Which years/models did you have?
2013 Max28XL shuttle""
"The loader valve sucks. The brakes suck. The manual transmission versions suck. At least that's my experience with Mahindra"
Loader valve does suck, then again my other machines cost a lot more new than the Max did.
Brakes? it's a tractor, I'm not doing hot laps.
Transmission sucks compared to a Mazda Miata, but compare the shuttle to other manuals on small tractors. 8 x 8 shifts well.
   / Choices, Choices, Too Many Choices #48
That was my FIRST impression too. Take a closer look and check the specs. There are *reasons* why it lifts/pulls less. IMO Deere used to be a fantastic tractor, and they have a TON of brand loyalty--almost rabid loyalty--but they are now coasting on their reputation while other makers are outdoing them in almost every way.
This is all talk. Test drive them all and then get back to us. (One of my "tests" was can the FEL lift the tractor off the ground in idle. Also bring a magnet; cast aluminum is no substitute for good steel. Compare the number/size of the FEL cylinders. etc.)
Agree the "proprietary" FEL/attachments is a major bummer.
There's a shop not too far from me that has a used BX for sale that he also rents. I'm thinking it might be worth it to rent it for a day to see what it will do on my hill. It doesn't have a mower, but I could still get a feel for driving up and down the hill and try out the BH a bit on some of the other things.
I've never used a SCUT of any kind, so this would at least give me a feel for the type of machine regardless of brand.
   / Choices, Choices, Too Many Choices #50
Yes! Do it.
Why is Mahindra so high?
Quote I got for the eMax 24 with BH, FEL, MMM and Tiller was over $27K if I used the 0% offer. Without that there are some rebates/discounts of around $4K, but still makes $23K which is well above some of the others I've seen.
   / Choices, Choices, Too Many Choices #52
Mahindra should be near the cheapest once all discounts are taken into account, except for RK. Note eMAX and MAX are completely different lines. So take a look at the MAX too (beefier). If the 24HP was really an eMAX, then I believe it would have to be last year's model (2017).
Did you drive it?
Can the JD (or other) dealers be talked into providing the service manuals with a new machine?
I may have already asked this, but just in case:
What is the purpose of 'remotes' and/or 'power beyond'? What are they used for and would I need one or both?
   / Choices, Choices, Too Many Choices #55
One of the more common uses for the rear hydraulic remotes is to operarate a top and tilt system on your 3 point hitch. It gives you the ability to adjust the angle and tilt of a rear implement without having to get out of the seat.
This is very handy for things like box blades where to get them to work as they should you need to make constant adjustments to pick up and then distribute dirt or gravel. It also helps to adjust the angle of the implement if you want to do something like create a crown in a driveway.
   / Choices, Choices, Too Many Choices #56
Power beyond would by used to power another valve, such as rear remotes, grapple, etc.
if the tractor has rear ports where rear remotes can be added, you should be good.
I would think that most ''newer'' tractors would come with PB. The loader valve on my old yanmar even has PB.
Many people (myself included) are using a 3rd function control valve to operate other functions like grapple, etc,.
OK, that helps some. Not sure how much of that I might be doing, but I'd like to be equipped for it.
But now I'm wondering about the LS XJ2025H which seems to be close to the same prices as the MT125, but with more lift capacity.
   / Choices, Choices, Too Many Choices #58
Ya just never know, You may want rear remotes down the road.
Which ever tractor you choose, you might ask how difficult it would be to install rear remotes at a later date.
My Kubota MX5100 is set up to add rear remotes fairly easily, if I choose to do so
The money .....
If I buy either new or used from a dealer, the financing is easier, but they collect sales tax.
If I buy used from a private individual, they don't collect the sales tax, but you have to finance yourself. Third party financing from a credit union or bank can be more difficult and expensive. Local CU wants 20% down and 10% interest for example.
I could pull the entire amount from a retirement account, but there is a 20% tax witholding. I'd get most or all of that back at next filing, but I can't pout it back in the retirement account.
   / Choices, Choices, Too Many Choices #60
The money .....
I would find a different credit union.My CU offers 5.49 % for 72 months on tractor loans.
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
2020 DRAGON ESP...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
