chipping trees with the Jimna 6 pto powered chipper
   / chipping trees with the Jimna 6 pto powered chipper #31
DeeDubya - - - I found the same problem with the Jinma release. Ended up taking it off and just putting a handle on the release. I also put a stop so I could hold the release handle in the release position for when I get things stuck which still does happen - - but not as often. Mostly when I try to feed too big a large forked branch.
Reggie
I chipped for about 4 hours yesterday and the only problem I had was the clutch for the feed rolller would disengage on it's own sometime. It seems that when the chute got filled with small branches and leaves it would pop open and then re-engage on it's own. I couldn't see what was actually causing it unless it was just the overload on the feed drive. I doubt that since once when a large limb got caught behind it and stopped it, it did not open and smoked the belt.
Hmmm, cant say on that. Its never been an issue with mine. The only time my belts smoked was when the exhause chute got jambed with chips. This was caused by the anval bar being spaced too far from the tooth blade. After i re-adjusted it to a dimes width, no more jambs.
TEST YOUR BID BUTTON! (A54757)
TEST YOUR BID...
UNUSED FUTURE AD680 HYD PILE HAMMER (A54757)
UNUSED FUTURE...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2016 Chevrolet Tahoe SUV (A55758)
2016 Chevrolet...
(3) CAT PALLET JACKS (A54756)
(3) CAT PALLET...
