chipping trees with the Jimna 6 pto powered chipper
   / chipping trees with the Jimna 6 pto powered chipper #31
DeeDubya - - - I found the same problem with the Jinma release. Ended up taking it off and just putting a handle on the release. I also put a stop so I could hold the release handle in the release position for when I get things stuck which still does happen - - but not as often. Mostly when I try to feed too big a large forked branch.
Reggie
I chipped for about 4 hours yesterday and the only problem I had was the clutch for the feed rolller would disengage on it's own sometime. It seems that when the chute got filled with small branches and leaves it would pop open and then re-engage on it's own. I couldn't see what was actually causing it unless it was just the overload on the feed drive. I doubt that since once when a large limb got caught behind it and stopped it, it did not open and smoked the belt.
Hmmm, cant say on that. Its never been an issue with mine. The only time my belts smoked was when the exhause chute got jambed with chips. This was caused by the anval bar being spaced too far from the tooth blade. After i re-adjusted it to a dimes width, no more jambs.
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI SGB20...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
5' CYPRESS GLIDER (A54756)
5' CYPRESS GLIDER...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
